FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
The starter solenoid has power on the main lug from the battery, as soon as the solenoid engages you hear the click but then I lose my 12volts on the main lug. Any ideas about where to start?
Check all battery cables and connections.-----Load test your battery even if new.----And if starter is original it would be a good idea to pull it apart to inspect brushes.---Little bit of grease for bushings.----Easy job.
I did all the above and if I take a jumper cable and go straight to the starter it will work. . But if I go thru the solenoid I have 12 volts on the main lug until the solenoid energizes.
Check your voltage across the battery terminals while activating the start circuit. If it checks OK, then you have a voltage drop somewhere between the battery and solenoid - probably a poor connection somewhere.
Well----I think that 12 volt circuits are very easy to trouble shoot and repair.-----The trouble might be that as simple as poor connections or bad ground.----Keep us posted on the outcome / solution-Thanks.
Symptoms strongly suggest a bad battery cable connection. Don't just look at them and wiggle them, remove them and clean them shiny clean and reassemble tightly.
