Seawolf_504
Thread starter- Joined
- Jun 22, 2010
- 11
I have a 15hp Evinrude on a 14' fiberglass fishing boat. I recently got the boat from my Dad to use on the flats around where I live. After doing a carb rebuild it runs really well and cranks up on the first pull every time, but I am having a problem getting up on a plane with me and my Wife in the boat.
I weigh around 250lbs and my Wife is around 130lbs. When I go to open up the throttle to full the RPM run right up no problem and it sounds like it is at full throttle, but it can't quite get on a plane. If I play around with the choke and pull it out about an inch or two the motor seems to jump up a notch in RPM and it's usually enough to get up on the plane.
I've already rebuilt the carb, changed out the coils, replaced the plugs and even got a brand new fuel tank, fuel lines, and placed a filter on the line coming from the tank.
Now my Dad said he always just used regular unleaded (87 octane), but I was thinking maybe throwing some higher octane in there to see what happens. Is using 93 octane ok for older 2 stroke engines?
If not changing the fuel does anyone have any experience with adjusting the throttle on these and should I get more power from this motor?
I'm a big guy and I know weight has a lot to do with it, but I have seen this motor get up on a plane no problem with me and my Wife in it, but it takes playing around with the choke to do it.
Any help would be appreciated.
