Sunken Ship
Thread starter- Joined
- Jun 19, 2014
- 252
I replaced the impeller and housing season before last, which worked great until now. I just pulled lower unit off and the impeller appears as good as new. Impeller key was also good. Sucked water out the exhaust with a vacuum cleaner. Blew air through holes. Installed a tell-tale, which also worked all last season. I did not see a thermostat on this motor int he diagram. I put thermocoupler on it and let it idle to 200f then shut it off. Gear box is turning water fine in forward and revers. Running in a garbage can. Any ideas?
