Yammerhead
Thread starter- Joined
- Mar 29, 2008
- 15
I have an 85 Evinrude that doesn't want to start cold. I can crank it forever with the cold start lever up and the electric choke on without even so much as a pop.
The primer bulb has been squeezed to fill the float bowls. I then cracked the bowl drains and let a bit of fuel out. I could then squeeze the primer a bit until it got hard again. That tells me the bowls are full and the floats / needles / seats are working.
I removed the carbs and cleaned them. They were pretty clean. I only found a bit of debris in one of the small (pilot?) jets. I put it all back together again with the same result, it would crank forever with no fire.
I shot a bit of gas in the throttle bodies and actuated the electric choke. I cranked it over and it immediately fired and ran at high idle. I shut it off and it would restart again right away. I put earmuffs on it and restarted and it ran good, shifted well and everything. I put the covers back on, quite happy with myself and left it for the night. Next day, I went back out and tried it. I cranked it over and again, it would not fire.
I pulled the covers off, shot some more gas in the throttles and it fired up again instantly. Runs good. I tried restarting it a couple it of times over a couple of hours and it fires instantly each time. Next morning, no go again.
Any ideas as why it won't fire at all when its cold? There is gas in the bowls, but it just seems like it woun't pull the gas up into the throttle bodies when cold. Should I add a primer circuit to squirt fuel into the throttle bodies to get it running??
