1975 Evinrude 9.9 help
tanuki
I have a 1975 Evinrude 9.9 that ran like a top last year and most of this year. All of a sudden (when the motor is warmed up) sometimes when I restart it the motor revs up extremely fast and I have to press the shut off button to stop it. It will do this many times and I have to keep shutting it down. It almost sounds like the motor is revving faster that wot (if that is even possible). After a while the motor will start and idle properly and run like a champ again. Last time out, motor ran properly to our fishing spot?I shut it down, anchored, fished for awhile, then when we were ready to leave I started it and it revved extremely high many times and I had to shut down again. I could not put it in gear as it was revving too fast. What I wound up doing was starting it and instantly putting it in gear ( I know, not a good thing) which made the boat lunge forward at wot. Went about 100 feet forward and then the motor ran properly again. Ran properly back to the trailer and when I got home and I flushed the motor in a garbage can it started and idled like a champ. I am a rookie with the motor, but I have learned a lot from this forum and ?Leroy?s site?. Any ideas on solving my problem is really appreciated.
Tim Frank
Re: 1975 Evinrude 9.9 help
First thing I'd do is a good visual of all the carb and throttle linkages to see if anything looks loose, or if there is something that might be causing interference/jamming
kbait
+1 w/Tim^. Sounds like the cam follower linkage(carb) needs to be lubed up. If it's sticky, that'll cause your symptoms. Pull the airbox and take a peek.
tanuki
@ Tim Frank and kbait....thank you for the info, will check next time I get to the boat and get back to forum.
tanuki
Update....pulled the airbox and saw nothing unusual. Looked clean and free moving. Sprayed some cleaner on the linkages and ran the motor in a barrel for 1/2 hour starting and stopping it. No high speed revving, but I will be taking the motor indoors for the winter now and do some preventive maintenance. Will clean up and lube the cam follower linkage, etc. as I tinker with the motor. At least now I know what to look for with the high revving problem. Thank you guys again for your input.
