First post on this forum - Looks like a great place for help.
Anyway, my 1975 Johnson 115 cut out at WOT last week. The motor was running great and then stopped like somebody turned the key off. I haven't been able to get it started since. It turns over just fine, but worn't start.
I first checked the fuel system since it is easiest. It looks like I'm getting fuel to the carb, but when I roll over the engine with the plug out it doesn't seem like I'm getting fuel to the cylinders. Any idea why I wouldn't be getting fuel there?
Also, I was thinking since it stopped so fast it may be an ignition problem. I checked the spark by sticking a screwdriver in the plug wire and holding it by the block. I got about a 3/16" Arc. Does this sound like a strong enough spark?
Any thoughts on this problem helps, I'm stumped right now. Thanks in advance!
