Boatist
Thread starter- Joined
- Apr 22, 2002
- 4,552
Motor ran perfect for 20 years but when the TCW 3 oil came out started having trouble fouling plugs. Trolling all day may have to change twice a day.
Ran OMC Engine Tuner to decarb the engine and also cleaned the carb and replaced the float and float needle. Blew out all the passages with carb cleaned and compressed air.
Did a compression check and got 120 and 125 psi.
Replace points and condensers and also one weak ingition coil.
Motor now starts and runs great but has one small problem Left.
Each Cylinder runs best at a different low speed carb adjustment. One runs best a little richer and one a little leaner. Range where both cylinder fire is very narrow.
Anyone have any ideas what I can do to get them closer to each other??
