baseball_guy_99
Thread starter- Joined
- Jun 24, 2010
- 22
Bought this motor, took it out to the lake...after giving it some throttle, it kicks out of gea (like i hit a log and the motor revved up). I could put pressure on the shift lever and it would still kick out of gear. Reverse works fine. So my first thought is clutch dog and forward gear. Well after seeing the price for those I hunted down a used LU.
Long story short, the prop shaft was too short so I gutted that lower unit and put everything into my LU. Took it back out today. Took off, got up on plane, bout 3/4 throttle and it kicked out of gear. The only things I didn't swap we're the shifting fork, the shift rod, and the pinion gear.
I also noticed that shifting out of gear into neutral, it doesn't always go into neutral. I have to jiggle it a little to get it to go into neutral.
Any thoughts?
Thanks in advance!
Any thoughts?
Thanks in advance!
