1975 johnson 40 hp prop help
hardwatergrampa
the prop on the motor is a 10 1/2 by 13 i hit a rock and need to change it i have several that fit the shaft or the hub on the prop is the same as the one thats on the motor 3 of the props seem to match what i have but i cant reed the pitch on them one that i can read says j 9 b calimbine its fits the motor but the blades are much wider should i use any of these or go by a new one thanks for any help mike
Boss Hawg
Re: 1975 johnson 40 hp prop help
Wow:eek:
How do you spell pronunchuation :confused:
Seriously, need to post question in Prop Section :rolleyes:
Lot of good help to be had there about props :cool:
henrye718
for what its worth I have a 12 1/4" 15 on my 40hp tiller.
