Re: 1975 Johnson 40hp Ignition Coil
usually both do not go out at the same time. i would suspect power pack or charge coil under flywheel.
Only cylinder #2 coil went out, that's why I only ordered ONE for clyinder #2.
The epoxy, glue, or whatever it is that is around the top and bottom, broke/came seperated and exposed the copper wires and all the guts of it. The crack is only 1/8in all the way around, but that's what I suspect is the problem, because I'm getting absolutely no spark to the plug.
I am, however, getting perfect spark on cylinder #1. Cylinder #1 coil is still in perfect, tip-top shape.
