Re: 1975 Johnson 50hp motor troubles
OK, I think I under stand your problem. Your lower unit has a pump in it to assist shift. The motor has to be at idle speed for it to go into neutral. When you get it to start, have someone watch the prop and see if it goes into neutral within a second or two. I may have asked this question before but do you have a factory manual for your engine, it will explain the operation of the lower unit.
