gnarbrah
- Joined
- Sep 20, 2007
- 140
Hi all - I've got this great little 6 horse that I recently got running again but I've got a new problem. It runs great for about 15-20 minutes but then it starts to "load up" and sputter real bad and gets worse as time goes on. This really only happens while in gear and the motor is under a load. I've replaced the plugs, taken apart the carb and given it a a rebuild with no change in performance. I also got the original factory manual and have been reading through thinking it might be something under the flywheel (points or coils?) Trouble is that I'm not sure what special tools I would need to remove the flywheel and any other parts to change these out.
Should I "fabricate" a special tool for this or am I getting in over my head? Also, does this sound like a reasonable problem that would cauise this sputtering? I've confirmed it isn't a fuel problem.
Lastly, I did remove the entire block at one point and replaced it without changing the gasket as it looked in good condition, could this be the problem?
Thanks for your help, I'm dying to get back on the water!!
Here's a video of the sputtering.
http://youtube.com/watch?v=pftB6TAzDKQ
