Gradywhite3535
Thread starter- Joined
- Dec 29, 2012
- 480
Hi all, so I tried starting my 1975 6hp johnson and couldn't get it going. I finally realized that fuel wasn't reaching the carb because I unscrewed the drain plug and no gas came out. I took apart the carb and cleaned it and all passages. I reassembled the carb and put it back. When I primed the fuel bulb I saw a milky colored fuel coming out of the drain screw. I kept priming In order to see if clear fuel would start coming out the drain plug to no avail. There are lead plugs and a big plug that I didn't want to take out because I was afraid I wouldn't be able o put them back in. Do you think I'm going to have to take these plugs out in order to clean out the carb better? What could be causing the fuel to get this milky color? The fuel I'm using was jut bought and fresh. Also this engine was running last year. Thank you
