I have only recently purchased this motor and i cant see a zinc anode anywhere on it, or where one may have been in the past.<br /><br />1. Does this motor require a sacrificial zinc anode and if so, where should it go?<br /><br />2. There is small fin that is mounted above but sits behind the prop, i figure it is an offset for steering/stability underway. At the front of this small fin there appears to be a small cut-out section; what is this small cut-out section for?
