1975 merc 850 water pump
merc75
i have never encountered a mercury like this do not know how to disconnect shift linkage it is not like other mercs i have with screw offs. can anyone shed some light for me?
Honorary Supreme Mariner
Re: 1975 merc 850 water pump
There is no shift linkage to disconnect !------Put control in forward and remove lower unit.-----Do not forget hidden screw under the trim tab.
Chris1956
Racerone is correct, there is a slip splined connection between upper and lower shift shafts. I prefer to drop the gearcase when it and the control are in neutral. That makes it much easier to synchronize the shift shafts, when reassembling.
Forward works just fine.-----Often the lower unit will jump to forward ( spring loaded ) when folks are not looking.----Then problems start on re-assembly.--------------Forward worked just fine 30 years ago.
