1975 Merc starts up, runs great, warms up, but then won't restart?
Grumpy Bear
So, my 1975 Merc 500 50 hp starts right up, runs great, warms up, but then won't restart (or has a very hard time starting back up) after it has been shut off for a few minutes. Here is what I've done so far: new gas (no ethanol), gas additive (Quickleen), new fuel pump kit, new sparks. I have carb kits coming in the mail. Any thoughts on why it would run great but then not run great after warm up and shut off?
Chris1956
If you pull up the cold start lever, does that help? I will guess it is flooding. The carb kits should help that.
Grumpy Bear
Thanks for the reply, Chris. Yeah, I pull up the choke and eventually it will start back up but it has no power and dies when I put it in gear. After several tries, I will finally get it to go and then it's fine again. Weird.
