1975 mercruiser - loose spark plug wire
brian8227
Hopefully someone can help me understand how this works.
Last week our boat died after a little sputter in the lake. We managed to get someone to help tow us to the boat ramp and we got the boat home. The boat would crank and crank but would not fire. I put some gas in the carb and it didn't fire. A few days later figuring it was now an electrical issue I pulled the middle wire off the distributor and held it to the engine to see a nice blue spark while cranking. So then I pulled the number 1 plug wire and was going to do a similar test to see if I got a spark on the wire. Well the boat fired up and I immediately turned it off. I put the wire back on the plug and noticed it did not click on and off like the others and was loose. I squeezed it with my fingers so it would snap on like it should and the boat fired up.
What I don't understand is why wouldn't the boat start with the wire loosely on the spark plug but it would with it completely off and on like it should be?
Re: 1975 mercruiser - loose spark plug wire
Ayuh,... Welcome Aboard,... What motor,..??
What drive,..??
When was the last time it was given a Tune up,..??
Points, 'n condenser,..??
Timin', 'n dwell,..??
How Bad is the cap,..??
Obviously the wires oughta be metered,...
brian8227
What drive,..??
140 3.0 liter
I don't know what you mean by what drive
Points and condenser and wires replaced a month ago as well as the timing adjusted.
We have a new cap but haven't put it on as it ran really well for the entire week.
What I am trying to understand is why when I removed the wire did it start to fire up and when I put the wire on tight it fired up but not when it was just loose. that doesn't make any sense to me.
