New to the forum and need some help.
I have a 1975 Mercury 500 - serial number 3723346 ( confirmed 1975)
I also have the Mercury service manual for the motor. I have no spark to the plugs. The manual describes the ignition system as " Lighning Ignition" - a Thunderbolt series. ( Has a distributor / driver that is belt driven)
To date: I've cleaned the distributor/driver and verified that I have voltage from the distributor/driver coils to the switch box. Initially, the ignition coil failed the ohm check on the seconday side (coil tower to ground) the primary side was good. I purchased another coil off of E-bay after confirming with the seller that the ohm readings are within specification for the primary and the secondary.
I replaced the coil after testing the coil myself - ohm readings ok on the primary and secondary readings - still no spark.
I have no way of checking the switch box - Thunderbolt Ignition analyzer required - so I ordered a new one ($180.00) - still no spark. I've confirmed voltage to the switch box while cranking (electric start) plugs removed. I do not have any voltage coming through the switch box to the green coil + lead.
Mercury switch has been disconnected / boat switch wiring disconnected at the switch box - blue terminal.
What am I missing ??? This old motor is making me look bad !!!!
Suggestions please - I'll buy the beer.
Docboat2@msn.com if you would rather e-mail - Knoxville, TN
