jakestevens
Thread starter- Joined
- Feb 11, 2008
- 55
I finally got a chance to put the 1975 mercury 650 2 stroke in the water last weekend. It wouldn't run enough to get it off the trailer. It would idle for a 10 seconds or so then choke out and die. I had replaced the trigger assembly and performed the timing and sync with the flusher (flaps), and it seemed to start and run ok, but when I put it in the water, it was like a different engine. Should I get a test tank and redo the timing and sync procedure?
