dimlight85
Thread starter- Joined
- Jun 24, 2013
- 6
I'm hoping to find some suggestions on how to get the lower unit off of this Merc I just purchased. It was a great deal...good compression, pumps water and shifts easy. The only problem, I got it home and cracked upen the lower unit screws to change the fluid and no oil came out, just fresh, clean water. The owner is someone I know and he had not used it in several years and with the easy that it shifts, I'm not worried that the lower has any gear issues.
Anyhow, the lower needs to come off to get to the seals and to check the impeller but I can't get the stinking thing off. What I've done so far:
Removed the two nuts; under the cavitation plate near water intake and the other above the cavitation plate on the front (in neutral). After removing those, I pulled with no joy and then tried using a rubber mallet and a piece of wood to tap it loose. I then tried getting some flat head screwdrivers between the lower and the upper all the way around and prying it free but did nothing but crack and damage the aluminum. Fortunately, it's nothing that some JB Weld can't fix. I left the nuts off and ran the motor on a in a barrel, shifting it heavily as someone suggested to break the shaft splines free. No joy there. Finally, I tried someone else's suggestion of loosening the six nuts that attach the powerhead and dropping it onto a padded surface on the floor (about a foot by a suggestion on another forum) to break it free...still no joy.
Am I missing something here? Any other suggestions on how to get this thing off? If I can get it off, I can change the seals and may end up taking it to a guy I know that's a pro at welding aluminum instead of the JB Weld fixes.
