mstone1968
- Joined
- Mar 1, 2005
- 60
Hello,
A friend of mine recently bought a boat with the above motor. It had set unused for several years when he purchased it. Would anyone have any suggestions on what would cause the motor to run out of gas at High Speed. If you run at low to med throttle, the motor runs fine and doesn't stop. But when you start running at full throttle, it will run for a while, then it just suddenly runs out of gas. When priming the bulb on the gas tank, gas comes out of the carbs. Is that normal? Any suggestions would be very appreciated. Thanks for your help
