1975 oday 22
1975oday22
my sails are in imaculate condition. original to the boat. i dont want to be throwing anchors. lol. thats why id sooner windless. ive seen 17-18 fters with windless. ive got enough room on deck for one.... and yes , the end of this month i will be installing the lights for the mast and wiring inside the mast.... safer and less headaches. still alot to do and get. still need a new vhf , a porta pot, new hose , probly new seals for sink pump, bumpers, dock lines, , ya the list goes on. lol. still have to seal the knot meter wheel. fix the bow rail. . yep i dont know about splashing this year but i sure am hoping too.
1975oday22
Just an update on progress. slow, but getting there. i installed blue led strip lights in vberth, installed small stereo also , cleaned the floor , going to be taking port side settee plywood off tonight. cleaned the starboard side settee compartment. gotta repaint under there, buying some equipment the end of the month. will post more as i progress.....
1975oday22
update on progress. decided not to go with windless. i have purchased more items . anchor bow roller, 3/8 150 ft anchor rope, more wiring, fish tape, another fuse panel, 4 way connector, and a companionway lock. . going to start work on the mast lighting asap when the items come in....
1975oday22
here is what i bought this round.
1975oday22
Just a small update so far.....decided not to go with windless. the lock i bought is bigger than i anticipated, but will work. the connector is smaller than i thought. but it will also work.... I am now waiting on my wiring and new fuse panel. the reason for this new fuse panel is because its 12 connect, its 300amp rated and will let me know exactly what fuse has blown. also because its ring terminal as opposed to spade connector. next on my list is bumpers, a new fortress anchor, and some other items wich i cant think of right now.
flashback
Good call, the deck and cabin top on a sailboat needs to be obstruction free as possible. Anything can trip you up.
1975oday22
small update. that lock i bought is huge. but works really well. i have got it mounted and operational. next will be the bow roller install, then the mast light connector , than last but not least the mast wiring will be done. then its just the small tidbits . (ie: Ring connectors to finish inside wiring, bumpers, vhf install ect)
1975oday22
bow roller is now installed. not sealed yet but installed
1975oday22
Good sized solar panel, what's your plans for that?
going to upgrade my battery to a 100ah or 200ah. depending on price. then will be installing a 4000watt inverter for 2 burner induction cooktop, keurig coffee machine, and whatever else we want to run while we are out cruising around. the panel is 100 watts and probly need another one or 2 for the setup im looking to do....
flashback
Ok I get it, I suppose the panels will be quick release so you can stow them down below when sailing.
1975oday22
the panel will not be on the bow .... thats just where i put it for now. i will be building a pvc mount on the stern sides so they flip down or up .... under way they will be folded down and at rest they will be in the up position.
1975oday22
got my last hole drilled last night. and amazingly enough with the holes i have drilled ( bow roller and now the mast connector) the deck is solid and bone dry. no soft spots anywhere. so i am assuming that this was well kept under wraps when not being used. but the 80 km winds dampened any soldering to the connector for mast lights.. yes i said solder. yes its a marine connector. as for being far from the mast. understand that i did not want to run the wires inside on the ceiling going to the mast connector . as all my wires run on starboard side it was the obvious place to put this. and its safe and out of the way. yes i know its a longer run for the mast lights to connect to. i will install wire clamps on deck to solve this problem . noone but me goes up on the cabin roof.
1975oday22
small hiccup in the process of trying to get this connector installed. i will not be using this at all. i will be upgrading to a deck connector from binnacle marine. i should soon be done with all wiring in the boat after this one. just the mast left. wich i have to drill the hole a bit bigger in order to get the fish wire to enter.
1975oday22
these are my sails. as you can see they are in perfect shape . and original to my boat
1975oday22
ordered my new gas tank, toilet and deck fitting.
1975oday22
so as it sits now, i will be picking up a cooler the size of tank, (12 gallon). either (1)- attaching it to under the existing locker hatch, or (2 )-cutting a new hole in starboard side seat towards transom to accomodate the cooler with lid for the tank, or (3)- cutting a hole in port side seat or wall to accomodate the cooler with lid for tank.
any ideas?
1975oday22
how would one fix this problem on deck?
flashback
looks like you need to re-bed the deck hardware, make some new mounting pads for the running lights,
1975oday22
would delrin work ok for the mounting pads? i still have a few pieces of it from when i built the chieftains console.
