1975 Starcraft SS 16 Rebuild
budski
photo210678.JPG photo210678.JPG photo210677.JPG attach9198586.JPG My son's 1975 SS 16 rebuild
dozerII
Good to see you back John, I bet you were starting to suffer from lack of restoration sickness!! Looks like a good project.
budski
Hi Glen the boat is totally redone now couldn't figure out how to start a new thread, finally figured it out o will post pics of rebuild, I do have some before and after pics on post a pic of your starcraft if you'd like to have a look at it.
Watermann
Man knowing and seeing she's already a finished product is like presents under the tree that aren't wrapped. :lol:
budski
No Title
photo210907.jpg photo210907.jpg photo210909.jpg photo210909.jpg photo210910.jpg attach9198591.jpg LOL Water We cut the original transum well apart and redesigned it to accommodate a live well and rear deck with pedestal seat.
budski
No Title
photo210913.jpg photo210913.jpg photo210912.jpg photo210912.jpg photo210910.jpg photo210910.jpg photo210914.jpg photo210914.jpg Prior to starting the interior we totally stripped the boat of paint and repainted it, Black again of course.
budski
No Title
photo210916.jpg photo210915.jpg photo210915.jpg photo210916.jpg Haven't quite got these pics in order
budski
No Title
photo210919.jpg photo210919.jpg photo210920.jpg photo210920.jpg photo210918.jpg photo210918.jpg photo210917.jpg photo210917.jpg We moved the windshield ahead by 4 inches and also extended the front deck by about 8 inches for the front pedestal.
budski
No Title
photo210921.jpg photo210921.jpg photo210922.jpg photo210922.jpg photo210923.jpg photo210923.jpg photo210924.jpg photo210924.jpg
budski
We covered the floor with marine vinyl and the rest of the interior with marine carpet.
budski
No Title
photo210925.jpg photo210925.jpg photo210926.jpg photo210926.jpg photo210927.jpg photo210927.jpg Came out pretty good we think, my son now thinks he wants a bigger boat probably a 17 or 18 so we're going to sell this one, would love to get a hold of another 18 V5.
budski
This boat and motor sat for about 4 years in someones back yard without being run at all, we changed the spark plugs cleaned the carbs a bit put in fresh gas with some sea foam and it started pretty easily compression was 112 on 2 cyls and 115 on the other 2.
dozerII
Very nice job, when you moved the windshield forward how far out to the sides did it move to compensate for the narrowing of the hull?
dozerII
Hey John just posted a link to an 18 V5 over in the StarCraft on Clist thread in the starcraft forum. Bit of a drive for ya but we are used to that.
Watermann
Looking for an 18'r here myself and that's exactly what I was thinking about doing, nice work bud!
budski
Hey Glen I'm pretty sure it only narrowed by 1-1 1/2 inches, we raised the councils so the outsides of the windshield sit partly on the gunnels.
Tnstratofam
Bud thanks for posting this it is exactly how I want to do my 16SS. I think she turned out really nice. So the new transom is tied in lower than the factory one at the gunnels correct? Also did you raise the bow platform higher than the original seat bases or is it at about the same height?
UConnMRB
Wow, nice work. These mid 70's SS Starcrafts are the only ones that I can find that look similar to my boat. Your works makes me very jealous.
Honestsam
What did you do to fill the holes on your gunwale. Did you replace any foam /flotation? I like your work you did the the aft area, is the port side the live well?
budski
Thanks all, , honestsam there were hardly any holes in the gunnels only small screw holes, we replaced all the flotation with rigid blue foam as well as the inside of each side below the rod lockers which had nothing there, and yes the live well is on the port side, the battery is on the starboard side. thstratofam yes the new transum is tied in lower on the gunnels, the front deck is the same height we used the same inside aluminum insert exept we shortened it.
