1976 135hp johnson problems
fishmonster13
have several problems with the motor first off it is really hard to start the first time, any ideas , just rebuilt the carbs. next is the lower unit it has a small vertical crack at the front of the housing about an inch long, is it weldable and it will not go into reverse after i pulled the lower to replace the water pump is a measurement for the shaft.
third when i run at wot she suddenly just dies on me , but will start right back up , floats to low?
fishmonster13
Re: 1976 135hp johnson problems
heres a pic of the crack, its the white line
