axeman1988
Thread starter- Joined
- Jul 25, 2011
- 58
well i'm a noob when it comes to outboards, i recently purchased an older valco with a 15hp ted williams outboard. the motor fires up nicely and fires on both cylinders. i'm under the impression that it is an air cooled powerhead/water cooled exhuast outboard. my only issue is the impeller. i know where it is an have taken it out a inspected it. my (question)s is the impeller blades or fins seem bent or curled a bit. it does pump some water out of the pee hole but not a superior stream and the water coming out does get quite warm. is this ok or does it need to be a stream simmilar to a jet on a waverunner?? aka the rooster tail? i ordered a new impeller from sears not cheap. could it possibly be the water tube traveling up to the power head? is there a seal up there? the tube didn't wiggle around a whole lot and i did use 10psi to blow through the pee hole to get any stuff that may be in there. other than that it runs like a champ. although the guy i bought it from said to use 50:1 mix to me that seems too lean any suggestions?? i figure 24:1 or 32:1
