- Joined
- Oct 25, 2011
- 25,294
Re: 1976 22' Starcraft Islander Rebuild
Yep,
DougFir, HeartPine are just 2 of the woods that will darken as they age, and if you can find CLEAR (non-amber colored) Spar Urethane it will not deepen the red nearly as much as the varnish did, but the wood itself will continue to darken w/ either. The wood itself will change colors, darkening over time. Urethane & varnish will also start yellowing over time, even the clear (non-amber colored). Darker windows (curtains?) would help reduce those reactions. If you open the can of varnish/urethane and it has even the slightest yellow/amber hue to it, it will yellow over time. If it looks like a can of thick water, then it may not ever yellow.
If that lighter look is what you're trying to get, I'd recommend 2 coats of spar urethane (clear), followed by 2-4 coats of water-based urethane. It is completely clear (amber free) & doesn't yellow over time, at all. It can be sprayed/brushed (but I don't like to roll it w/ either foam or knap rollers), it dries really quick, and in quick application of a 2nd coat, doesn't require any re-prep. Drying quickly greatly helps it dry dust/bug free. :spider:
It does have a much longer cure time between dry to the touch & being cured enough for a light scuff before coats 3 & 4.
Of note, however, is water based poly doesn't have the same tactile feel of oil based spars or urethane, and the grain must be sealed w/ an oil based product 1st. Otherwise the grain will raise, and give unsatisfactory results....
PMC: Jas does have a very Starsky-esque look about him, all he really lacks is the bad 70's mustache
{que the 70's nrop music}.....
What about using both. Vinyl for the main covering and the wood for some trim or accent. Not sure but you may find that even if you sand the wood down over time it is gonna darken and regain that red patina anyway.
Yep,
