1976 22' Starcraft Islander Rebuild
jasoutside
Re: 22' Starcraft Islander Rebuild
Since this one certainly holds the "curl" and is starting to crack, surely time to change it out...
So here's the inside of the pump housing with the stainless impeller cup...
Ant then the base plate off...
So here's the housing. I'm wondering if that rubber junk came from this seal in there, probably...
Given my issues I decided to go with a whole new pump rather than just the impeller, BRP/OMC gear (rather than Sierra/Mallory, $$$)...
Here's a comparison of the old (upper) parts to the new (lower) parts. The kit comes with extra stuff, specifically grommets (1 for short shaft, 1 for long shaft, 1 for 4 stroke) and a small O ring (used on some models, not mine)...
jasoutside
Now it's time to start putting it all back together. Fist I cleaned/degreased everything. Then I laid a very thin layer of grease + the base plate...
Here's the new housing, no rubber hanging out...
Long Shaft grommet popped into place...
Impeller spun into the impeller cup (little dish soap is good here)...
I globbed on just a bit of grease to that flat section on the drive shaft to hold the pin in place...
Very carefully lined up the notch in the impeller with the pin and slid down the housing...
jasoutside
And on!
Bolted up...
Glob of grease at the drive shaft splines...
By the way, here's my favorite grease...
Way better than no grease. You can find that at any fine grease shop here in the Midwest:thumb:
Next up was just bolting up the Long Shaft extension...
jasoutside
Now here's what happened on my coupler - it appears on the last water pump maintenance the fella stripped everything out, rats!!!
So after coughing up $$$ for original OMC parts for a new one, time for assembly. Now, the key to get this right (therefor avoiding stripping everything out) is to get that "shoulder" perfectly into the coupler for the screw to slide through...
How I did it was jam my knee under the skeg and lift the lower unit into place. At the same time I was pushing forward on the shifter with my left hand to bring the shift shaft perfectly into position. With my right hand I was lining up the bolt to the coupler. I rand out of appendages otherwise you would have got an interesting photo of me making this move! K, bolted up, nice...
Shifting into reverse brings the lower unit up some to make lining up the bolts easier...
All bolted up!
Water pump maintenance complete! (Besides the water test certainly)
jasoutside
Next up was swapping out the lower unit gear oil. Here there is a lower drain/fill screw (NOT to be confused with the Phillips head screw next to it) and an upper vent. Pop off the lower screw, drain...
Kinda dark but no signs of water so that's good.
Hook the pump to the lube bottle, and the hose to the lower fill (more OEM $$$ stuff here, I suppose I don't go bottom feeder on everything)...
Start pumping till gear oil comes out the vent...
Replace the vent screw...
Then the fill screw...
Clean everything up, check for leaks, done! So easy even a Kanuck could do it!
Now I realize most of this stuff is preeeeety basic. But, I thought I'd post up for a fella who may not have run through this basic maintenance before and the info might be helpful.
As for me, I've only barely even touched marine engines (IO and OB) so I'm a total absolute rookie with all of this stuff.
Anything and everything I know to this point comes from right here on iboats (So thanks a ton guys!). Another excellent resource is Leroy's Rambelings, totally awesome...
Welcome to LeeRoy's Ramblings
Anyhow, if you guys see anything I did wrong or needs correction/clarification by all means jump in:thumb:
From here I still need to work through the electric start issues on this kicker, clean/prim/paint/decal, but I'm in no rush.
Gibbles
Re: 1976 22' Starcraft Islander Rebuild
Looking good, and a little trick I learned from a marine shop, dish soap on the new impeller.
I had 2 new impellers burn up on my lil 9.8hp merc kicker (went out before it even pumped water), so I bought my final impeller from a local shop and they mentioned their use of dish soap on new impellers.
also I have only changed out one evenrude impeller and it was a pain in the butt, merc uses a splined/keyed male and female shift shafts so no silly method to get the shifter free, you just have to make sure the shifter on both ends are in the right position when putting back together.
Only problem with that design is rust, hard to get oil in the splined area, but later mercs switched to stainless (seems so obvious right?!).
jasoutside
Alllllrighty, so, Islander thread note: I'll be MIA for a while. I just hit the "Unsubscribe ALL" button.
The Jasoutside family is running a no "Fbook" (iboats for me), cable is a gonner, and low internet usage plan for a stretch here. I should be back when we mark The Kings Rise.
Have a good one fellas!
:peace:
dozerII
Nice job Jason, play x play was bang on, I even caught the jab at us Northerners.:fencing:
laurentide
Thanks for the water pump tutorial, jas. I'm about to do a couple of those, and this is the most thoroughly documented process I've seen! This should be a "stickied" topic.
jetterbug
Nice write up JAS! As always, I'm inspired by your work.
GA_Boater
Time to upgrade your data usage plan, Jas? :grumpy: Those caps are major suckage.
The only thing in you tutorial is greasing the WP gaskets. They (it's true, I read it on the Internet) say grease allows the gasket to squish out when the bolts are tightened and to assemble dry. On the good motors anyway (Mercs). LOL
See ya when your I-Net frees up. Careful when you start posting all the pics of the progress you make in the mean time or you'll be bouncing off the megabit ceiling in no time. :)
EDIT - Never mind the data cap junk. I am a DUNCE. See ya Easter Sunday or there abouts.
magnumdeke
Good work on the rude!! and enjoy your lent sabatical!!! See ya after He is arisen!
Ayuh,.... I see ya found the Green label variety,... Nice Score,..... :joyous:
See ya after lent.... ;)
64osby
Jas, Nice pictorial. I have two of those to do come spring.
Store up lots of pics. Going to miss the daily treats and updates.
Haven't seen that brand of grease, I'll keep looking:becky:
Bwana Don
:peace:
God Bless the Jas Family during your celebration of the "40 days" of Christ's journey into the desert, or as Catholic's call it Lent.
c.peet
I wonder what's happened to Jas? The King has returned by now. Maybe the Jas family have enjoyed the Island too much and have disappeared from civilisation... Oxymoron, I know.
jasoutside
OK, yah, I'm back hanging on iboats, though not much happenin with the Islander since the Evinrude saw action up there^^^. My mid range plan from here is to get back after the cabin bulkheads, work through a couple/few small structure items, and then start working on paint prep (there's a lot to do for that, boring).
The good news is I still fully intend to float this boat this summer and I'm really looking forward to it!:thumb:
jasoutside
Well that was a pretty boring post, sorry!
Here, this is more fun...
third times the charm
Just glad to see you back on the islander, she deserves some water time this year. I need to catch up here on the thread, later man
craigweaver
Welcome back! in your honor I sacrificed a FG hull in your absence :facepalm:
