1976 55 Johnson not charging
lmuss53
I read the CDI TS guidelines which don't address not charging on this motor. I searched and found nothing going beyond the rectifier test. I did the Joe Reeves rectifier test which shows the rectifier to be OK.
Is there an OHM test for this Stator?
How much should it put out in AC volts at idle, and can I check that with one of the high end ($300 plus) Fluke meters from work or do I need the DVA adapter on all meters?
I just bought the motor, and the stator looks to be recently changed.
I have a factory manual on the way, it should be here tomorrow.
The motor is a 1976 55 Johnson model 55EL76E.
lmuss53
Re: 1976 55 Johnson not charging
I've got a DVA adapter on the way, can someone help me out on where to check and what to look for?
