byronjacobson
Thread starter- Joined
- Jul 28, 2009
- 44
First question. I have about a 76 johnson 6 hp where i put in a new water pump but it still doesn't pump water. Pretty sure i got the water tube lined up and also the key placed correctly on the shaft of the water pump. Any ideas what to try before i take the lower leg off again. I had a heck of time getting it back together before, but hopefully will go easier the next time if i have to do it again. when i took the thermostat cover off, very little water was coming up to top of the block. I did blow out the water tube openings with water and air and they seemed to be clear.
second question. this motor will keep running but only if i keep squeezing the primer bulb. what does that mean as far as doing repair?
third question, I misplaced the thermostat cover, gasket and screws so if any one has a similar 6 hp where you selling parts please let me know. thermostat cover part number is oem 0312714. believe these parts are similar on 6 hp johnsons from 68-79. please respond to my email if possible at jake331@charter.net or on this site. I find this site full of information but hard to use and understand. took me a long time to even figure out how to post a new thread. thanks for any help you can give.
Byron Jacobson
Byron Jacobson
