Royce Brown
Thread starter- Joined
- Jul 10, 2018
- 37
I broke the pinion gear on my 1976 6HP Johnson outboard, need to replace the old plastic gear, the teeth were heavily worn and I seem to have snapped off a piece that I believe the retaining clip latches onto. When I pull the cord it sounded really "chunky" compared to the normal sound, and I located a broken piece of what looks like a plastic washer in the bottom of the motor case.
I've found videos walking through how to redo the recoil assembly but I'm not sure how to remove the actual pinion gear (P/N 318447). A roll pin (P/N 309686) appears to hold the pinion on but I don't know how to remove it, does it just pull out or is there some type of trick to it?
Thanks, Royce
Thanks, Royce
