1976 70 hp Evinrude will not shift in to forward or reverse
Elfred
My 1976 70 hp Evinrude does not shift into forward or reverse when the shifter is moved. Engine runs fine. Was coming into dock, shifted ti neutral and then tried to go forward. Thanks for any help.
Daviet
Re: 1976 70 hp Evinrude will not shift in to forward or reverse
Have you checked to see if the shift linkage going to the lower unit is moving?
boobie
Also check your shift cable for being broke.
Davied
Is this electric shift?
boobie
The last mtrs to use electric shift were the 1972 models.
