StickyWidget
Thread starter- Joined
- Aug 2, 2011
- 72
I have a 1976 75HP Evinrude, I have rebuilt all 3 carbs and replaced spark plugs. I checked compression and spark on all cylinders.
Service place is saying I have no spark on second cylinder.
The boat runs high idling, and will die if you slowly accelerate the throttle under load.
If I tap the choke and gun the throttle it will run WOT all day long. Every time I want to get back to WOT I would have to tap the choke in at the same time.
After rebuilding, all I've done, nothing seemed to change it's operation. I bought a timing light and it was reaching the appropriate max RPM (5600 I believe).
When I spark tested it last year, it looked OK to me. 7/16th Gap it jumped I believe.
This motor has run the same since I've owned it for about a year now. I took it out on the river the same day I put it in the shop, it still was running the same.
They say it needs a new power pack to the tune of about $150 for the part alone. $300 something to do it.
My questions:
Can a powerpack be "bad" and still jump a 7/16th gap?
Does my engines running the way it is look like it could be the powerpack?
Can a powerpack intermittently work? I haven't noticed surges in power at all.
How hard is installing a powerpack?
In a 15ft tri-hull fiberglass boat, would a bad powerpack still allow the boat to hit 30MPH? I have had this boat at that speed and pulling tubes all summer, seems like it couldn't do that on two cylinders but what do I know.
I don't intend on paying their prices if at all possible just was hoping for a "you tell me whats wrong and I'll fix it" approach.
Any help you can offer would be appreciated.
My questions:
