1976 75hp johnson top cylinder wont suck
75-JOHNSON
all three pistons have 120 psi compression. top cylinder wont suck very well. put some plastic wrap over carb ports and middle and bottom suck the plastic right in when you turn it over but top barely does anything. switched around reed valves and still no difference. any ideas?
F_R
Re: 1976 75hp johnson top cylinder wont suck
Throttle linkage sync????
OR, there is more to compression than the compression readings. Compression is affected by rings and cylinder walls and is the pressure above the rings. Two-strokes also have compression below the rings. The piston skirt is a big factor in that. What I am suggesting is a blown piston that still has the rings intact.
75-JOHNSON
is there any way to remove and examine the piston without splitting the crank case? is it possible to remove the connecting rod bolts through the carb side of the engine?
red boat
Do a compression test. If you dont have a compression guage you can get a loaner from most auto parts (o'reillys, autozone etc) I think you will find that top cylinder is low on compression. Oops just reread all cylinders have 120psi compression. On some motors you can get to the connecting rod bolts without splitting the case but you wont be able to get it back together correctly without splitting the case.
jimmbo
The crankcase seal in the bearing block on the top of the crankcase might be bad. This would prevent the crankcase for the top cylinder from inhaling/exhaling. The cylinder compression will still be fine since it can still pull air back through the exhaust port.
75-JOHNSON
thanks guys, i took it apart and the bottom ring was broken, however it did not cause any scaring or anything which is good news.
