1976 85 hp evinrude
ahmincha
Going to look at a 1976 85 HP evinrude anything I should look for . Thanks in advance
F_R
Honorary Supreme Mariner
Re: 1976 85 hp evinrude
Completeness, is it all there, including the remote control with wiring harness? General condition. How does it look. nice or pile of doo-doo? Signs of ovrheating, is the paint on the powerhead burnt or discolored, any wires melted where they touch the block or heads? If you get this far, and the seller allows it, pull the plugs, looking for any signs of rust in them. Then check the compression. Check the oil in the lower unit, is it full and free of water?
The things I just listed are the minimal basics. If it fails any of them, figure you are buying a possible money pit. If it passes, can you take it for a test run? Or does it run at all? Then there is the Judge Judy question, "Did you have a mechanic look at it?"
Bottom line: You pays your money and you takes your chances. How much are you willing to risk?
emdsapmgr
Well-said. The cranking compression on that engine when new was around 125 lbs on each cyl. I'd expect to see the current compression within 10% of that figure.
ahmincha
I know this is a loaded question but if all things mentioned above check out whats a fair price to pay
classiccat
What's included? (tilt/trim, controls, prop(s), wiring harness, gas tanks / capacity, etc.)
rdmotors
If you can check the fire also, sometimes the control box can be a little expensive.
ahmincha
Controls wiring harness prop
