1976 85 hp johnson reverse plunger
badog229
I was lookin to buy a boat and the guy said the reverse plunger was out of it and he said it was only about 40 bucks im new to boating and wondered if anyone new what he is talking about and if their was a link that might show a pic of it any help would be greatly app Thanks
badog229
Re: 1976 85 hp johnson reverse plunger
He said reverse wasnt working any ideas :confused:
crb478
either something is shot i the lower unit and it will be more than $40.00 or the cable is stretched or miss adjusted. Try to take the cable off and see if it will slip into reverse by hand. If it won't then you might want to look at a different motor or for a new to you lower unit.
tashasdaddy
could be many things some expensive, some just an adjustment. bad cable, as said above, misadjusted shift rod height, or a bad clutch dog or oil pump in lower unit.
badog229
Thanks i think i will pass on this boat and find one i dont have to work on before i use it thanks again
jonesg
smart move, if is so easy to fix with a cheap part, let the seller do it.
