1976 85hp johnson (throttle cable djustment)
skruff33
hi i was wondering if anyone could help,ihave a 1976 johnson 85hp motor,and i recently changed the control box and up graded with neww ignition,now the throttle cables r all out of whack..and also the warm up cable....does any1 have a clue on how to adjust them .....a a diagram or walk me thru in a message it would b greatly appreceiated.......thanx Bob........
emdsapmgr
Re: 1976 85hp johnson (throttle cable djustment)
The throttle cable adjustment is done at the engine end. Disconnect the throttle cable from the throttle lever on the engine. Normally, that engine throttle lever will move to the idle position. If not, make sure it is in the idle position. Put the control box lever in neutral. Adjust the cable so that it exactly matches the throttle lever and reconnect it. The throttle cable is adjusted by screwing the threaded casing nut on the outer cable-engine end. You may find that you need to make a minor adjustment to the casing nut.
