1976 Evinrude 15 hp 15605A
Davem3
is this a long shaft or a short shaft, and what would it be worth, please???
Dave
Monte1961
Re: 1976 Evinrude 15 hp 15605A
short shaft and depends on condition. Post back
Davem3
thank you monte and will post tomorrow, will look at it then :)
Davem3
it ended up being a long shaft.
got a 1976 evinrude 15HP SS instead, a little problem when i went to change the water pump, but nothing JB Weld could not solve.
Damn, i thought 500 was high , but when you look at CL............. well at least it runs super smooth, has new Powerpacks and well i tore into the water pump just because.
good thing i did, because a chunk was missing on the port side wall, and some idiot fixed it by putting in a rubber piece. useless, and did not do squat. can't wait to see how much more pressure i get , but gonna wait 24 hours before i do anything to let it get solid first.
my current issue is the rod to adjust the tilt is rusted and frozen into place, any ideas on how to get it out ????
Monte1961
You can try a little heat on it and see if that works?
Davem3
thanks, Monte. Doing that and going through a can of PB Blaster as well.................working on a patience issue, i seem to have lost mine . LOL
