chevysam41
Thread starter- Joined
- Jan 29, 2016
- 59
Excessive slop is definitely an issue with that twist grip - I need to look at that in more detail.
DOH! I know for a fact that the spark plugs were in (except the one I was testing, obviously). Guess that's what I get for doing it late on a Monday night. I've always removed all of the plugs when doing compression tests on car motors, but I've never understood why that matters...will it really throw off readings? Its supposed to rain here the next several days, so I'll do another compression test over the weekend after running some seafoam through the motor.
I snagged an old plastic barrel from work and started up the motor yesterday. I had a heck of a time getting it started on muffs last week, but on three separate attempts yesterday, it cold started within two pulls from a barrel. Ran like a top after I adjusted the carb. I let it idle for probably 8-10 minutes, put it in gear, etc and it seemed to run fine. I have a laser thermometer and the temperature got up to about 165* after 3 minutes or so, and just as I was about to shut it off, it dropped to the 120-130* range and stayed there. I'm guessing that was when the thermostat opened up as I was measuring at the top of the head. I thought those thermostats were supposed to open at 130*, but maybe not.
