Putzaroni1
Thread starter- Joined
- Oct 20, 2012
- 108
I have a 6hp Evinrude that is very clean. I started at the bottom and cleaned and greased the prop shaft, replaced the Water pump impeller and the thermostat. I then pulled the carb, cleaned it thoroughly and tried starting it. It runs but only idles and then eventually dies. I tested the 2 plug wires and one of them has a weaker spark than the other. I believe the is likely a coil but I'm all ears if I should be checking something else.
I tried to pull the flywheel off and cannot get the nut to let go. I had a strap wrench but it broke.
What do you guys use for a strap wrench to hold the flywheel ? I'm going to need it to hold well as this is going to take some torque to get this off.
Any recommendations on a strap wrench would be appreciated.
Any ideas on getting that nut loose and
Is replacing the coils, condensers and points the right approach to getting this thing back to running like new again ?
Thanks
Thanks
