1976 Evinrude Gearcase leaks
Alabama(AL)
The gearcase on my 1976 Evinrude 25hp Model #25603E / Serial# E0006339 Leaks out of 3 HOLES on the top of the Gearcase is this common or is there some type of seal that may be bad. it has has a recent water pump confused change.
lindy46
Re: 1976 Evinrude Gearcase leaks
There are small weep holes (about 1/8" diameter) That allow the water/exhaust residue to drain from the leg - perfectly normal to see stuff coming out when you pull the motor out of the water.
