catalyst-519
Thread starter- Joined
- Mar 12, 2008
- 64
Hey Guys.
This is an addition to my previous post about my 1976 Evinrude 9.9 and the misfiring troubles. I've spent a lot more time trying to get to the bottom of this and here's what I've found so far.
Went to the marina to buy a new coil and the mechanic suggested that before I buy a new ignition coil I swap the two of them and see if the misfire occurs on the bottom cyl, as it was occurring on the top cyl once the motor reached operating temp. In addition, the low idle is really rough and often misfires or coughs out.
I swapped the coils, got the motor up to temp and the top cyl is still misfiring. When I pull the top spark wire, the misfire stops, until the cyl loads up and stalls. This says to me it's not a problem with the top ignition coil.
After reading the article at
www.sschapterpsa.com/ramblings/Johnson 9.9_15.htm
This guy suggest that it's likely bad condensers and that swapping these may solve the problem.
I pulled the flywheel and see that there are 2 additional coils. 1 single and 1 double. I suspect that the single is the ignition and the double is the charge coil, but I really don't know.
If anyone could take a look at these pics and help me out it would be great.
My question: Should I be replacing both magneto coils, points and condensers all in one go, or can I get away with one coil and the condensers. IF so, which coil is the likely culprit.
I'm lost and this is the last attempt before I go to the mechanic but I'd rather not if I can handle this myself.
Help is greatly appreciated.
Cheers---519
Cheers---519
