paulhaines2000
Thread starter- Joined
- Feb 17, 2011
- 10
I've got a 1976 Evinrude 15. It does not have a pee hose out the back so the indication the impeller is working is water spitting out a port near the top of the lower unit. Recently it seemed to be taking too long for the water to come out as the other engines I have start peeing within a few seconds of starting. Yesterday I filled a plastic garbage can with water well above the exhaust to run some sta-bil through the fuel system for storage. It ran for a minute and no water so I shut it down. I pulled the lower unit and the impeller (almost new) looks fine as well as key installed properly. I ran water up into the impeller housing area with some water muffs and all looks clear. I noticed a chunk of what might be gasket meterial in the bottom of the exhaust of the lower unit but not sure what material it was. I put a fuel hose on the copper tube that goes up to the power head and blew on it and there seems to be no obstruction. Does it sound like I have a blown powerhead gasket? Is there tests to perform before I pull stuff apart? Is there any other gaskets on the heads that can cause similar issues that I need to look at also?
