1976 Grady White Transom Rebuild
demarko210
Here is the other. Is it ok to start to use 60 grit grinder to sand the rest of the wood out or I still need to chisel?
kcassells
Now that looks like you can dig into it now. Nice!:D PB is still a pia but you can load more pics etc.When's the floor coming out?
demarko210
kcassells
I didn't plan on doing the floors this year. I will wait till the fall to demo. Trying to get back out on the water.
kcassells
If the tramsom is that deteriorated............just saying. I know I'm no fun but whats the point of replacing a deteriorated transom with new to rotten stringers? It's just gonna go that way. :)
demarko210
@kcassells
Its fun to me, because I never done it before. I bought the boat in 2012 and have been researching transom work since a friend (my mechanic) worked on the engine and told me about the transom was soaked And that the stringers are likely too. I just feel I would rather tackle the obvious problem of the engine flying off as oppose to stepping through the floor. After I finish the transom I will do stringer later after I research more about foam when i never even fiberglass before.
demarko210
Here is another picture. What I did today for about 1.5 hours.How deep do I need to dog in the corners? Main this worx 14in chainsaw is killing this wood. Great invesyment.
kcassells
Your gonna need to remove all wood till you hit glass. Yup it is fun doing something new and challenging. No wood patterns should be left when your finished, just smooth glass.
The newly revealed glass becomes your new bond for the transom install. Think of it like leaving paint on the glass and glassing over the paint. The bond is to the paint, not the glass, it will pull apart.
demarko210
@kcassells
I have an earlier picture of the bilge where there is a crack in the floor. I keep thinking my deck was sealed, then i removed the cap yesterday and seen a .5 inch hole going under the deck. So yes i know in will have to get under there. Hell like the room with that cap off would love to have a full transom on here.
demarko210
I will keep at it with the chainsaw and chisel. The port Side I can see the glass on the side so I got that ok. The drain hole, do I need to remove that too? Got about 1 inch of wood before I get to it.
kcassells
LOl ...the turtle wins the race. But try not to fall asleep. Cool side is I just got a bunch of goodies and prepping wood for the new gastank. Got 4 days off so here I goes again.
kcassells
You're challenges aren't so different than what I ran into. Keeping an eye on your work I am. Figure in a month you'll be teaching me.
demarko210
kcassells
Haha. Do you have an idea about how much mat, and 1708 I need for the for the entire job stringers too? I was going to buy (1) 5 gallon of polyester
kcassells
I'm an EEEEEEEEEEEEpoxy guy not poly but WOG/Woodonglass will chime in I'm sure.
demarko210
@Woodonglass
Hey can you give me an estimate about how much 1708, mat I need to do transom, stringers, and deck for 76 Grady White weekender 19ft. Thanks
demarko210
Hit some glass now I see how far I need to go. I though the wood was smoothing out but it was the chainsaw making the wet wood smooth. I saw different layers until I saw glass then I was tired. Picture is looking down from outside out the boat.
kcassells
Set it on some level 2x4's off the ground and cover it up with a tarp.
Wog nessd some material quotes for ...whats it called? oh yea poly.....not EEEEEEEEEEEEEpoxy.
We need the Wizard of WOG! Woodonglass
demarko210
@kcassells
I made up my mind about doing the stringers after looking at this video on shipshape tv. They were saying about laying out your grid for your under deck layout. I would like to add 2 things when putting it back together, live well and a ice box. I keep saying if just fix the transom and wait, I probably keep putting it off. Like you said do it while you got it out.
Where and how should I cut? Can you let me know and how?
