B.johnson1993
- Joined
- Apr 24, 2017
- 25
I have a 1976 johnson 115, it’ll start up fine, when I go to shift it, most of the time it won’t go into gear, engine will rev up, also the throttle control, seems like when it does go into gear, I have to push it further than usual to get it up to speed, then for reverse it barely pulls backwards. And every once in awhile when I start the boat, it’ll be in reverse some how? Shows it’s in neutral on the throttle control, but when the boat starts up the prop is spinning backwards even though it’s supposed to be in neutral, any help is appreciated... maybe something messed up in the lower unit? Or the adjustment is way off?
