Seahorse16
- Joined
- Jun 23, 2013
- 86
When I got this motor last fall I drained the lower unit oil and got a nice milky water surprise, so I knew I likely needed to replaced the lower unit seals. I also noticed dark black oil coming from around the prop. Still, I replaced the lower unit oil and took it for a test drive, and then I also ran it in a barrel.
In order to make an attempt at changing the seals I drained the lower unit oil again, and was surprised to find it clear of any water. However, after leaving my lower unit in a barrel for a week the water turned black (on the surface) from black oil leaking out from prop. Attached are pictures from inside the lower unit with prop removed. I'm not that familiar with the plumbing setup. It this just residual oil from the exhaust coming out prop? Or is this another seal somewhere I need to fix?
I saw a youtube post of a guy drilling into the seals, then putting in screws and pulling the seals out. Is this something worth trying? The tried to pressure test the lower unit, but my brand new compressor died (need to take it back tomorrow). I figured I would replace them anyway since I dropped the lower unit.
Also, how do you know when impeller needs replacing (picture attached)? I will probably do it regardless since it's pulled, but just curious.
Sorry, I know that was a boat full of questions, but I appreciate all help or suggestions!
Trevor
