Re: 1976 Johnson 200 hp lower unit removal
I'm pretty sure I got all the pieces cleaned out half a can of goof off and two hours with a flat head then I hooked the muffs up and pumped water through it to clean any other blockage out seems to work fine now, would it hurt anything if I hooked a garden hose up to the water line running into the motor with the bottom drive off to make sure all the ports are cleaned out and flowing good?
