1976 Johnson 35 hp Tell-Tale???
jay1000000
Re: 1976 Johnson 35 hp Tell-Tale???
hi, i had something similar years ago on an 8hp suzuki. exhaust gases were getting into the water pump thru a corroded hole. when u rev up the exhaust gases over come the water pump pressure and gases came out of my tell tail. at idle was fine. a leak between the water jacket and exhaust could cause this. i.e the exhaust manifold. i have the reving up when cover is off problem. im guessing its because i don't have a silencer on the carb.
