1976 johnson 55 hp
willie0691
hey all i hope some one can help me with this problem trying to remove the lower
unit have removed all the bolts & the trim tab but it wont drop. its not my first
lower unit but none of the things i know to do work :confused: any one got any ideas Thanks.
WillyBWright
Re: 1976 johnson 55 hp
Did you also get the bolt up inside the cavity above the trim tab and remove the shift pin under the carbs?
willie0691
got the bolt but did not know about the pin under carb
how do i remove the pin and can it be done without removeing carb?
Thanks!
76SKPR
does anyone have the schema or service manual for the 76 55hp. I'm having problems with the power pack
thanks
