1976 Johnson 55hp seahorse lower unit lube question
pontiacfieroguy
What is the correct lube to use? I've read 80w9 0 gear oil, mercron atf, specialized omc lube, and motor oil and I have no idea what is correct.
Honorary Supreme Mariner
?????-----That gearcase and gears are not the most robust.------Use OMC / BRP brand called HY-VIS gear lube.
