1976 Johnson 60 hp reliability question
freeville69
I am going to look at a 76 Johnson 60 hp tomorrow. Anyone have input on the reliability of this motor? Know of any issues to watch out for? I need to replace my 72 65 hp for the season so I can look into some shifting issues without taking my boat out of service for an extended period. Any input would be appreciated.
tashasdaddy
Re: 1976 Johnson 60 hp reliability question
nothing out of the ordinary.
BUYING A USED MOTOR
overall condition, condition of the place you are buying it from, usually tells you how they care for things. compression 100 + psi, and within 10% of each other, good strong blue spark, no water in the lower unit oil. look for discolored paint, (sign of over heat at
one time, also scarred up bolts, as why. have them start it. if they fail to put it in a barrell or tank, or on muffs, or in the water, to start it they don't know what they are doing. best yet is to take it for a 30 min to 1 hour test run. also if remote controlled motor, the controls should come with it.
Hydro Electric Shift)
(J. Reeves)
The shifting setup of the lower unit is what's called a "Hydro Electric Shift", which is quite complex consisting of voltage being applied to solenoids in the lower unit which in turn change oil passages via a oil pump that supplies various pressure on a spring loaded shifter dog. The wires leading to the lower unit (at the powerhead) are "Green" and "Blue". The engine must be running or cranking over in order to shift out of forward gear.
You CAN NOT use HI VIS lube in that lower unit. You MUST USE what OMC calls "Premium Blend" lube, commonly called "Type C". (A thinner lube)
In neutral, you need 12v to the "Green" wire.
In reverse, you need 12v to both wires, the "Green" one and the "Blue" one.
In forward, there should be no voltage to either wire. (The spring loaded shifter dog forces the unit into forward gear)
To check the lower unit for proper shifting to make sure you have no trouble there, remove the spark plugs to avoid problems and to allow a higher cranking speed.
This next step eliminates the actual shift switch in case problems may exist there.... Disconnect the blue & green wires at the knife connectors (the rubber insulated boots) leading to the lower unit at the powerhead, then using jumpers, take voltage direct from the starter solenoid to apply voltage to the "Green" wire for neutral, then both wires 'Green" & "Blue" for reverse (Remember the engine must be cranking over in order to shift).
With no voltage applied, the unit should be in forward. No need for a ground jumper... the lower unit's already grounded. You may crank the engine with the key switch or by energizing the starter solenoid with a jumper wire.
freeville69
Hey tashasdaddy, thanks for the input. when referring to the hydroelectric do you mean the 72 65 hp or the 76 60 hp? The 65 hp which I currently have I know is hydroelectric, and that one all I have been able to troubleshoot is that it has power to the green wire to the lower unit but still starts in forward (no reverse either). After I ran in last time (shifted fine at first then started in forward after stopping to fish for a while) I drained the lower unit and the oil was all milky like it was mixed with water. I think I need to replace the lower unit if I can find one as the housing has a crack in it, not obvious enough to notice when I bought it. Yup I got burned on this one because I did not know enough when buying.
tashasdaddy
this was for the 76, nothing out of the ordinary.
BUYING A USED MOTOR
overall condition, condition of the place you are buying it from, usually tells you how they care for things. compression 100 + psi, and within 10% of each other, good strong blue spark, no water in the lower unit oil. look for discolored paint, (sign of over heat) at
one time, also scarred up bolts, as why. have them start it. if they fail to put it in a barrell or tank, or on muffs, or in the water, to start it they don't know what they are doing. best yet is to take it for a 30 min to 1 hour test run. also if remote controlled motor, the controls should come with it. your 72 controls will not work with the 76,
